SLP Paddle Kit necessary for 4:10's??
Old Feb 22, 2004 | 07:07 PM
AdamZ1LE28's Avatar
I will soon be installing Richmond Street Gears 4:10 ratio in my '96 z28. It has a 7.5" rear end, just like all other 82-02 z28's came with, i think. Anyways, i just read that I need a SLP Paddle kit ($169.99) in order to install 4:10's in this rear end. Is this true, or are they just trying to make some money? Thanks
Old Feb 22, 2004 | 07:39 PM
AdamZ1LE28's Avatar
ttt
Old Feb 22, 2004 | 08:16 PM
rpm4lalo's Avatar
I have Motive 4.11's in mine and my mechanic installed them without the paddle kit, he did say he had to grind on something though.
Old Feb 22, 2004 | 08:18 PM
xxsaint69x's Avatar
same here...something needs to be ground down a LITTLE bit.
Old Feb 22, 2004 | 08:29 PM
will62085's Avatar
whats a paddle kit? i installed mine without anything like this...
Old Feb 23, 2004 | 12:39 PM
LT4Firehawk's Avatar
The SLP paddle kit is only for cars that came with the Zexel Torsen differential. Since you have a 96 Z28 and not an SS, you should be able to use any 3 series carrier 4.10s without modification. All the GM LT1 cars and some of the LS1 cars came with the base Auburn differential. The Zexels were only available as an option on SLP cars (Firehawk/SS) and stock on late LS1 cars.
Old Feb 23, 2004 | 01:46 PM
BigRich's Avatar
we had to grind the paddle a little even w/ 3.73s and the Torsen
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
QuickSilver02
Apr 7, 2015 11:12 AM
