Engine miss vapor lock?
Old Feb 23, 2004 | 12:55 PM
chrism400's Avatar
Unhappy Engine miss vapor lock?
My stock 95 LT1 camaro with 100,000 miles runs pretty well except when it has been running for a while, shut off for about 10 to 15 minutes, and restarted. It idles fine, starts ok but, when given gas, it stumbles, and backfires in the intake a bit. It doesn't have full power for about 1 minute of driving. Then everything clears out and it runs great. I noticed a bit of a cold start problem this winter and actually had to pump the accellerator to start it. I don't know if the two are related or not. Thanks
Old Feb 23, 2004 | 01:16 PM
96capricemgr's Avatar
Vaporlock can only happen when the pump has to suck fuel out of the tank like on carbed engines with the pump mounted to the block, your car has a submerged(in gad) fuel pump.
Old Feb 23, 2004 | 01:53 PM
Still could be a fuel problem, though. You might have a leaky injector or a bad fuel pressure regulator.
oldschool
Feb 9, 2016 09:21 PM
ro2207
Dec 4, 2014 06:18 PM
centric
Aug 15, 2002 09:04 PM
squirrels
Jul 13, 2002 01:58 AM
