SLP LT4 or McLeod ST???
Old Oct 8, 2003 | 11:15 AM
  #16
Grover's Avatar
Re: Re: SLP LT4 or McLeod ST???
Originally posted by IllusionalTA
If you aren't concerned w/ price and don't mind working out that left leg a lil.. The Street Twin is worth every penny.. and can be rebuilt time and time again for 325 dollar's.. i have it and it has only snapped one driveshaft, one output shaft, and twisted the spline's on 3 steel driveshaft's.. Uprgraded to a spohn extreme duty and don't have no more problems..
When you say you upgraded to a spohn extreme dute are you talking about the torque arm?
I have also snapped one driveshaft and twisted the splines in the slip yoke of a Denny's Nitrous driveshaft.
Old Oct 8, 2003 | 12:01 PM
  #17
J's 82's Avatar
Originally posted by 95Blackhawk
Here is what I did:
Went down to Autozone and bought myself a new clutch for $250 (some area of US sell it for $200). It will have a warranty and it uses the LT4 pressure plate which gives you more holding power.
Now, later if you start to wear the clutch again, just get a new disc. If you want, try a different one from Spec.
I just did the same thing.. the pressure plates are identical down to the serial numbers.. the whole setup 199.00 and holds just fine.. don't think you can beat that deal..
Old Oct 8, 2003 | 12:45 PM
  #18
WOOS1's Avatar
Identical to which one? The SLP?
Old Oct 8, 2003 | 12:48 PM
  #19
zhevy-1's Avatar
Another vote for the ST. Grabs like a mad dog, a little hard at first on your leg, but you'll get used to the feeling. I really like it.
Old Oct 8, 2003 | 05:48 PM
  #20
J's 82's Avatar
Identical to a mcleod pressure plate I have in my garage.. only the autozone one is not painted red.. every number matches including the manufacturer.. I posted about it on here before apparently it is some sort of patent by valeo on the pressure plate..
Old Oct 8, 2003 | 06:32 PM
  #21
Moore94Z's Avatar
I have an SLP PP with a Mcleod kevlar/organic disk. it's listed as the performance disk for shifts above 7500 RPM. I'm really happy with mine. I've beat the **** out of it and it never slips, is 100% as driveable as stock and doesn't chatter. At your power level I'd reccomend either a stock disk or the Mcleod with an LT4 or SLP(LT4 with holes drilled) pressure plate.
The ST is overkill for a bolt-on car. You could get away with a new stock LT1 setup just fine, but a mcleod/SLP combo is very similar in price.
Old Oct 8, 2003 | 07:56 PM
  #22
KENS96M6's Avatar
If you think you will ever use a power adder, you will need the ST. Yes, my wife can drive it, although it has a little more peddle pressure.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
