SLP LT4 or McLeod ST???
My clutch has been giving me problems for over a year now (I don't put many miles on the car in a year). I can't take the slipping clutch any longer. I want to buy a new clutch, and don't mind dropping $1K + my labor if that is what it takes. I don't want an on/off type of clutch. A good friend of mine has an LS1 with a Cartek clutch, and it is just too aggressive. I want it where my wife will still be able o drive it if she wants to raise a little cain. My car is basically stock. Will have long tubes on by the end of the month. Hope to do a medium heads/cam install before next spring: will never be over 385 rwhp. Also I thought I've heard of people running a LT4 pp and McLeod disk. Anyone have this setup?
Here is what I did:
Went down to Autozone and bought myself a new clutch for $250 (some area of US sell it for $200). It will have a warranty and it uses the LT4 pressure plate which gives you more holding power.
Now, later if you start to wear the clutch again, just get a new disc. If you want, try a different one from Spec.
Re: SLP LT4 or McLeod ST???
i have it and it has only snapped one driveshaft, one output shaft, and twisted the spline's on 3 steel driveshaft's.. Uprgraded to a spohn extreme duty and don't have no more problems..
I thought the street twin was okay about driveability. I think one part is organic and the other part is some other stuff, ehh I'm just thinking out loud.
I used to have a spec stage III ceramic. That thing BIT HARD!!! It was an on off deal. But man could I chirp fourth when all I had was a cutout and free mods =) Don't think about it in traffic either.
Right now I'm using the SLP LT4... it's holding with the blower fairly nicely. I think with any more it will start slipping though. Do what somebody else mentioned and what I plan to do, get the SLP LT4 and if you really want another clutch later just get a disc from clutchnet or spec stage II kevlar or something like that.
I have the ST, feels just like my stock clutch. The thing grabs HARD though when it's time to play. I dropped to 4th on the freeway with a mustang trying to ride my tail hard.
I think I scared the ish outta him
So it will snap your neck
I get slight chatter in 3rd i think, nothing major though.
And for a personal plug, I have a brand new one for extra cheap if your really considering getting one. Check the FS section.
I get slight chatter in 3rd i think, nothing major though. And for a personal plug, I have a brand new one for extra cheap if your really considering getting one. Check the FS section.
So you can slip it pretty easily?
I've had the SLP disk and the McLeod performance disk. From my experience the McLeod perormance disk is much stouter than the SLP. I'm not knocking the SLP disk, but if you want a reasonable cost disk and can't afford a more costly package (and perhaps don't need the McLeod ST), the Mcleod performance disk is the best choice.
Originally posted by WOT
That's what I'm going to be doing. Waiting for my SLP disk to slip then putting a McLeod (that's sitting on my garage shelf) in.
Originally posted by "White Knight"
Go Harsh.....that's what is fun! even though i drive an auto Z......
I can slip the ST with no problem.
Put it in first from a stand-still, then slowly let the clutch pedal out. It will slowly gain speed until it fully engages, with a bit of a jerk. But up until full engagement, it will slip smoothly.
When it is "engaged fully" it will not slip, however.
Unless you have probably 900+rwhp.
The pedal is a bit firmer than stock, but certainly not a pain for DD'ing.
The aluminum flywheel version weighs less than the stock setup, so you'll save some rotating weight on the engine too.
Unless you have probably 900+rwhp.The pedal is a bit firmer than stock, but certainly not a pain for DD'ing.
