SLP Intake
Old Jul 25, 2010 | 07:41 PM
lt1le2's Avatar
SLP Intake
Can someone please tell me what they are using with there slp intake or what can I use to connect it to the MAF everything I have is to small looks like the slp is like 4" pipe and maf is 3.5" anyone have any ideas.
Thanks,
Old Jul 25, 2010 | 08:01 PM
brucer's Avatar
i think mines using the stock piece that connected to the old stock airbox..
Old Jul 25, 2010 | 08:15 PM
lt1le2's Avatar
slp
anyone have any part numbers
Old Jul 25, 2010 | 08:44 PM
brucer's Avatar
can you get a pic and post it... i have an slp on mine and it measures 3.5 inside diameter, same as my maf..
Old Jul 25, 2010 | 09:09 PM
lt1le2's Avatar
slp
my maf end goes in the slp intake all the way. does yours do that or is it the exsact same size as your maf end
Old Jul 25, 2010 | 09:18 PM
brucer's Avatar
the slp intake is 3.5 inside diameter, your maf will measure 3.5 somewhat over the outside, thats why it will fit inside the slp cold air intake... i know the maf is 3.5 od i measured mine the other day to order an elbow from the throttle body to the maf... i didnt measure the cai though, but from memory i know there is a stock rubber peice between my maf and cai... wish my car was at the house, i'd go measure mine for you.
i bet you could get a piece of 3.5 inside diameter rubber hose to work... home depot will have it for cheap.. look in pvc pipe area..
Old Jul 26, 2010 | 06:17 PM
brucer's Avatar
ok made it to the shop today... the slp cai measures 3 3/4 outside diameter.. so you will need a 3 3/4 to 3.5 reducer to connect to your maf..
Old Jul 26, 2010 | 11:19 PM
lt1le2's Avatar
Where can I find those at
Sent from my ADR6300 using Tapatalk
Old Jul 27, 2010 | 12:30 AM
brucer's Avatar
i just ordered a 4.0 to 3.5 90deg. reducing elbow from them, should be in in a couple days.. i'm going to order me a 3.75 to 3.5 reducer soon as money gets swapped into paypal..
try this link
http://www.siliconeintakes.com/produ...46fa8ae37be9c7
HarleyZ28
Oct 5, 2015 06:23 AM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
R@mpage
Apr 20, 2015 10:02 AM
