SLP Fan Switch Install Question.
Old Jul 7, 2003 | 09:13 AM
Jeff - '97 Formula WS6's Avatar
Question SLP Fan Switch Install Question.
When running the wires through the firewall did you use the existing hole being used by the factory wiring? If so did you have the SLP wires go through the factory rubber seal/grommet?
Thanks,
Jeff
Old Jul 7, 2003 | 09:15 AM
scoobysnax83's Avatar
they say to do that. And yes that how I did my home made one. I believe you have to remove the PCM to get a good shot to it.
Old Jul 7, 2003 | 10:01 AM
PaulN64's Avatar
just run it through the factory grommet. That's what I did with mine, but I did the fan mod w/o the SLP switch. I didn't want to spend $70 when I could spend $6
Old Jul 7, 2003 | 10:31 AM
Re: SLP Fan Switch Install Question.
Thanks,
Jeff
The big grommet is a good place to run the wires.
Maybe you would consider shortening your sig to 5 lines per the forum guidelines and as a courtesy to others?
Old Jul 7, 2003 | 03:24 PM
Re: Re: SLP Fan Switch Install Question.
Yes that is quite ridiculous....Try to save from putting each one on a seperate line. You could separate with a comma. Most people do around here.
Old Jul 8, 2003 | 07:43 AM
Smile
Thank you all for your advice. Sorry about the signature...I will take care of it.
Thanks,
Jeff
Richardan15
May 30, 2015 08:36 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
slothgrant
Aug 22, 2002 03:01 PM
