slp cold air intake
Old Sep 11, 2003 | 10:06 PM
KW95TransAm's Avatar
slp cold air intake
I was wondering if anybody has any description and knows any websites that could give me some information with some illustrations on installing my new slp cold air intake for my 1995 Trans Am???
Old Sep 11, 2003 | 10:09 PM
CamaroBoy96Z28's Avatar
Re: slp cold air intake
Its pretty self explanatory. Pull the old air box out put the CAI in its place. Take off the splash guard on the driver's side and put the filters on. Should take no more than 20-30 min.
Z95m6's Avatar
i believe brent has one, and probably www.projecttransam.com
Old Sep 11, 2003 | 10:57 PM
jim88iroc305's Avatar
Re: Re: slp cold air intake
It's different on a T/A because of the headlights. If you have a fax numbet I could fax you the instructions which came with mine. I think you can pull off the install instructions somewhere on the site.
Good luck
Old Sep 11, 2003 | 11:04 PM
RedPhenx's Avatar
what exactly are you having problems with? I also have a 95 and have the slp cai with dual cones.
edit: the only part that may be a problem is the little bracket is sligthly different right behind headligts.. and also, you *may* have to move the box for the lights. it will be a tight fit trying to get around it.
Old Sep 12, 2003 | 07:11 PM
Re: Re: Re: slp cold air intake
Good luck
Ahh I forgot about that. I knew the headlights come into play a little bit but not the fine details. I stand corrected, well good luck with the install.
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
slothgrant
Aug 22, 2002 03:01 PM
BM93Z
Aug 22, 2002 02:45 PM
