CC306 sounds less aggressive than the hotcam?
Old Sep 12, 2003 | 01:33 AM
97Camaro007's Avatar
I just put a 306 in my car and it sounds about the same or weaker then the hotcam....i haven't got it to the track yet because i have a fuel pump that is pumping 23-25 psi at all time......would that make the car not sound too aggressive....i know a lot of you have done this swap so let me know what you guys think about the sound.
Old Sep 12, 2003 | 01:44 AM
S.J.S.'s Avatar
I didn't know the Hot Cam sounded agressive at all. I'm throwing one in my 383 and wanted it because its gonna be an everyday car. Did the Hot Cam have a lopey sound to it?
Transamdriver's Avatar
My CC306 was loud at idle for the first 200miles or so, now its smoothed out and gotten a lot less choppy at idle.
Old Sep 12, 2003 | 08:27 AM
Camaro_Maniac63's Avatar
Without any tuning, the Hotcam has a pretty lopey sound to it.
Old Sep 12, 2003 | 05:06 PM
so the cc306 is suppose to sound like it does...? I mean my hotcam had tuning done by pcmforless and the cc306 doesn't seem to be hitting any harder than the hotcam......I couldn't even tell that I had even changed cams......don't know about performance yet becuase of the fuel pump...i should be here in a few days...but i figured that from a hotcam to a comp cam 306 that it would have made it sound a little different.....
Old Sep 12, 2003 | 05:56 PM
Josh-'04 GTO's Avatar
I wouldn't really give it a lot of thought until you get fuel into the motor. If it is still the same, I would get it on a dyno and see what is going on.
Old Sep 12, 2003 | 06:43 PM
FireAm94's Avatar
The cc306 I hear DEFINATELY did not sound like a friggin hotcam.
Joe
Old Sep 12, 2003 | 06:52 PM
MEAN LT1's Avatar
The 306 does not sound like the hot cam, the 306 is more of a chopey sounding cam where as the hot cam sounds more like actual mild lope.
Old Sep 12, 2003 | 07:12 PM
bad95z28's Avatar
maybe you got the cams mixed up and put the hotcam back in. J/K, that would suck though wouldn't it..... Get the fuel to the motor and see what happens.
MDZ28
11
Sep 24, 2015 09:15 AM
rvonsternberg
Sep 14, 2015 11:58 AM
95craz28
11
Sep 12, 2015 07:47 AM
jackpawt883
Sep 10, 2015 08:53 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
