SLP billet flywheel
Old Mar 15, 2007 | 07:39 PM
theroad64's Avatar
SLP billet flywheel
My 355 has an Eagle internally balanced rotating assembly. I recently purchased an SLP billet flywheel for it. My question is: Should I take the time to have the thing neutral balanced? What about the balancer on the front of the motor?
Old Mar 15, 2007 | 10:41 PM
There is no "balancer" on the front of the engine - its only a harmonic damper. It is neutral balanced.
Since your engine is "internally" balanced, you need a neutral balanced flywheel. The SLP piece probably has the weight on it for the stock "external" balance.
Old Mar 15, 2007 | 11:41 PM
SS RRR's Avatar
Even if a manufacturer claims their flywheel to be zero balanced you should have it checked out by a machine shop to ensure it is truely zero balanced when installing onto an internally balanced engine. The last thing you want to do is take a flywheel that is used for an externally balanced engine and put it on one that has been balanced internally. Take it to a machine shop and have it neutral balanced.
Formula Steve
Sep 19, 2023 08:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
Jlo
Jul 29, 2015 03:52 PM
