SLP 25# injectors. Flow like SVO 30#?
Old Jan 28, 2004 | 10:15 AM
DR.ZED's Avatar
Any experience with these injectors?
Apparently they flow like 30# SVOs?
Any truth to that?
Old Jan 28, 2004 | 11:20 AM
QCKZ28's Avatar
no experience with them.
it says 25# at 3 bar (stock LT1 fuel pressure 43.5psi)
30# SVO are rated at 39.5psi,
so the 30# SVO will outflow them quite a bit.
those injectors are just a little bit bigger than stock
stock being #24 for 94-97, #22 for 93 models.
hope this helps
Old Jan 28, 2004 | 12:20 PM
DR.ZED's Avatar
It does. Thanks.
Old Jan 28, 2004 | 05:12 PM
They are probably not any bigger than stock. The injector constant for the stock "24#" injectors is 24.9
Old Jan 28, 2004 | 05:33 PM
bigj96z's Avatar
just out of curiousity what would be the outcome of puttin bigger injectors on a stock motor...i.e. no cam stock heads and stock manifolds?
Old Jan 28, 2004 | 06:30 PM
QCKZ28's Avatar
you need to have your injector constsant programmed accordingly. there would be no performance gain or loss.
Quickss96
Jan 29, 2016 05:56 PM
Queens94z28
Sep 20, 2015 08:45 PM
Jlo
Jul 29, 2015 03:52 PM
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
