Slow cranking problem.
Old Apr 27, 2004 | 10:21 AM
94Z28WP's Avatar
My car turns over slowly for about 2 or 3 seconds before it starts... Does it every time I crank it, no matter if it's been run for an hour or just starting in the morning... Battery tests at 12.6 volts... With a load, the battery drops to a little below 11 volts... I'm getting 12 volts to the starter... The purple ignition wire at the starter tests ok... I cleaned the ground connection at the motor mount along with the ends of both cables... I removed the starter and had it tested at 2 places and both said it was good... It acts as if the timing is too far advanced... I've replaced the optispark so I know there's no way it could be install wrong and the timing be off... I'm stumped and up for any suggestions. 94 Z28/ A4 /61,000.
Old Apr 27, 2004 | 10:28 AM
Red96Lt1's Avatar
Have you checked the alternator?
Old Apr 27, 2004 | 11:36 AM
93transam1234's Avatar
i would try another battery, if that works get your battery and alternater tested. if you ask nick most gas station will do it for free if they arnt busy
Knightscrapper
Feb 4, 2016 10:25 AM
jwade88
Jun 14, 2015 09:38 PM
beltrunner
May 17, 2015 10:18 PM
rocknroler69
Apr 29, 2015 10:24 PM
greenzee28
Mar 26, 2015 09:13 AM
