slop in new LT1 timing chain?
Old Nov 7, 2005 | 06:39 PM
oneqwkfbody's Avatar
hey all, helping my friend work on his 96 z28. the new chain we put on it has about 1/4" play in it --left to right. i figured its a new chain anyhow, and buttoned her up.
anyone else find this when replacing with a stock timing chain. i put a cloyes double roller on my 93 and that thing was tight. any info lemme know...we should be trying to start it here near the end of the week.
thanks
brian
Old Nov 7, 2005 | 06:42 PM
12SCNDZ's Avatar
Re: slop in new LT1 timing chain?
Cloyes makes an over sized crank sprocket for just this reason. I can tell you it make a huge diffence in my new Lunati chain.
Cloyes makes one for a stock style chain.
Frank
Old Nov 7, 2005 | 07:30 PM
1racerdude's Avatar
The oversized crank gear is the same as a SBC. They put the slop in the chain to relieve the pressure on the front cam brg. It has enough pressure driving the water pump. If ya got an electric WP then ya can run the "oversized gear". The small gear is LT1 spect only.
Old Nov 9, 2005 | 07:01 PM
1racerdude's Avatar
Originally Posted by A/G
I don't understand how driving the water pump will affect the chain tension. Please elaborate racer. It is my understanding there was an error in the specs GM originally sent Cloyes.
The WP pushes straight down. A tight chain pulls straight down were as a loose chain will pull off to the side in the direction of rotation,distributing the load more even.
There was NO mistake on the spects given to Cloyes,if there were don't ya think it would have been corrected after 12 years. It is the way the General wanted it and Cloyes made it. They also make one with "oversize" crank sprocket that is the same as SBC if ya want a tight chain.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
