slick tires selection
Old May 6, 2004 | 08:14 PM
1BadBrd's Avatar
Either MT E.T. Drag which many people say they aren't much different from the E.T. streets
or
Hoosiers
looking for slicks not drag radials
Old May 7, 2004 | 06:27 AM
IDOXLR8's Avatar
Re: slick tires selection
or
Hoosier Quick time
If you are still running a stock 10 bolt then I would highly recommend going with a Drag Radial. If you want something a little sticker than I would recommend a MT 26x11.5x16 ET Street. Remember the sticker the tire the more prone you are to breaking something.
Old May 7, 2004 | 07:32 AM
1BadBrd's Avatar
i should have mentioned that i just installed a Moser 9" yesterday
Old May 7, 2004 | 09:21 AM
TedH's Avatar
I use Et Streets.
Since I enjoy bracket racing in street class, plus many tracks have street tire only nights, I like to use a DOT approved tire so I am less limited as to when I can race.
At high 12's at 107, ET Streets would be fine for you.
Mickey Thompson makes a size, 26" x 10 1/2" x 16, part number 3792 that will fit on your stock rims.
I went to a 10" rim so I could use a slightly wider tire, but an ET Street will provide nearly the same traction as a full slick and significantly more than any drag radial that I have seen.
You should check out the Micket Thompson site at http://www.mickeythompsontires.com
They even have pre-sales support phone numbers to help you pick the right tire.
Et Streets are designed for use with tubes and I use them. Not everybody does, but when my butt is travelling over 100mph I like to play by the manufacturers recommendations. If you decide to use tubes you will need to enlarge the valve stem openings. Also, any low pressure soft compound tire MAY spin on the rim. I use rim screws because mine to spin but many folks do not have this problem.
Old May 8, 2004 | 05:07 PM
1BadBrd's Avatar
does anyone have Hoosiers
Old May 8, 2004 | 08:39 PM
"White Knight"'s Avatar
How do tubes handle on the street?
2QUIK6
Sep 17, 2016 02:31 PM
Boss002
Jul 24, 2015 10:47 AM
Latronaxe
Jul 20, 2015 12:00 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
