Size of EGR "nuts"
Size of EGR "nuts"
Does any one know what size nut that is on the bottom of the EGR/AIR tubes? You know...the gold one that can slide up...What I am trying to do is get a bolt that is the right size to put in my emissions equipped pacesetters fittings on the first primary and then weld up the tube on the pass. side header. Thanks, Brad
Re: Size of EGR "nuts"
Which tube or tubes did you mean?
RX Speed Works
Aug 20, 2015 03:40 PM
I guess I just mean the AIR tubes...thanks.
