Displacement and Emissions
Old Apr 8, 2005 | 08:22 AM
NBred94's Avatar
I was reading the thread about the LE1 package being worth it and a couple of comments raised my curiousity a bit.
With all else being equal (cam, heads, etc) will a 383 have lower emissions than a 350? Granted, a setup optimized for a 350 will not be optimized for a 383, but if there is a general rule, I'd like to understand the reasoning. Thanks.
Old Apr 8, 2005 | 09:38 AM
RE AND CHERYL's Avatar
Re: Displacement and Emissions
As a general rule a large cam will not effect a stroker as much as a stock displacement engine, but what dirties up your exhaust is the valve overlap. As lift duration goes up this will increase. Loyd will flatout tell you none of his cams will pass emissions, this is mostly due to the 110LSA they are ground on. Even in a 383, they probably still won't pass the sniffer test. Your just gonna have to get a smaller cam, maybe somethinf like the 224/230.
Old Apr 8, 2005 | 11:17 AM
OldSStroker's Avatar
Originally Posted by RE AND CHERYL
As a general rule a large cam will not effect a stroker as much as a stock displacement engine, but what dirties up your exhaust is the valve overlap. As lift duration goes up this will increase. Lloyd will flatout tell you none of his cams will pass emissions, this is mostly due to the 110LSA they are ground on. Even in a 383, they probably still won't pass the sniffer test. Your just gonna have to get a smaller cam, maybe somethinf like the 224/230.
You might check with Lloyd again. Some of that may have changed.
sleeperZ96BT
Sep 9, 2015 08:28 AM
TGGodfrey
Aug 18, 2015 06:08 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
BadIroc
3rd Gen / L98 Engine Tech
12
Jul 17, 2002 12:38 AM
