simple ? simple answer. pace setter LTS, in through top or bottom
Old Jan 21, 2006 | 03:06 PM
hulettsz28's Avatar
Pace Setter LT Install, do i go in through the top or the bottom? which is easiest?
thanks
will
Old Jan 21, 2006 | 03:37 PM
scottslt1z28's Avatar
Re: simple ? simple answer. pace setter LTS, in through top or bottom
bottom..........then u dont have to worry about taking off the valve covers and replacing those gaskets
Old Jan 21, 2006 | 04:09 PM
LT1 POWR's Avatar
Drivers side goes in through the bottom. Passenger side can go in from the top if you remove the valve cover but it can also go in through the bottom. You will probably have to jack up the motor quite a bit to get them in which is why when you do a header install it would be a good idea for some new motor mounts.
Old Jan 21, 2006 | 04:30 PM
TJ Chapman's Avatar
i just had the car on some ramps, and both sides came real close to going in from the bottom. just for insurance (to not scratch up the coating on everything, i jacked up the car a few more inches and they both went in from underneath. its a bit of a struggle, have some buddies, and a good imagination, twist and turn a bit, and they'll go in
Old Jan 21, 2006 | 04:48 PM
Evil Eric's Avatar
bottom...take off the oil filter and the starter, dont try to go straight up and in with the header. I put mine in at an angle, Kinda rolled it up and into place. You'll see what I mean when you install them.
Old Jan 22, 2006 | 03:13 AM
The Anti Riced's Avatar
Got mine from bottom, had to pull passenger side valve cover, but did'nt have to jack up motor. My knuckles looked like I changed a blade on a running lawn mower.
Victor Lamb
Aug 26, 2017 02:52 PM
REDNECKISBOSS
Apr 17, 2015 07:14 AM
cmsmith
Mar 14, 2015 03:48 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
