silencer fell off and lost it!
Old Sep 24, 2003 | 09:11 AM
tryingtomakemycargofast's Avatar
if the silencer were to fall off would it make the car bog like crazy?
Old Sep 24, 2003 | 09:17 AM
LeftoverChinese's Avatar
What exactly is the silencer?
Are you refering to the muffler or the donkey dong thing hanging from the intake? If you lost the thing hanging from the intake then you need to plug the hole otherwise you are letting in unfiltered air.
Old Sep 24, 2003 | 09:19 AM
LT1TONY's Avatar
Yes it would because you would have a big vacuum leak. Either get the LT4 one since it doesn't have a silencer or go buy yourself a shampoo bottle of Pert Plus and stick the cap in there. It's a perfect fit and then just zip tie it real tight. Mine has been in there for quite a few years and hasn't fallen out yet.
That will fix your leak.
Old Sep 24, 2003 | 09:21 AM
intake
i talking about the one hanging from the intake.....and my car is bogging really bad. could this be the reason??
Old Sep 24, 2003 | 09:27 AM
94Zpower's Avatar
yes it will cause a bog because the air comming in through the hole is not being metered by the Maf, but capping it with a pert cap or herbal eessences bottle worked great for me going 2 years now. or if you wnat the silencer pm I have an extra one lying around.
Gary.
Old Sep 24, 2003 | 09:28 AM
LT1TONY's Avatar
Yeah, your talking about the elbow. Underneath that there is a long donkey dick thing hanging. This is a silencer. Plug that hole up as I stated on my previous reply.
Old Sep 24, 2003 | 09:30 AM
head and shoulders
what about head and shoulders bottle?
Old Sep 24, 2003 | 09:33 AM
LT1TONY's Avatar
I believe that is the same bottle. Just pull your elbow off and check out the opening. It's kind of oval looking.
Old Sep 24, 2003 | 10:25 AM
stereomandan's Avatar
Looks like you found your problem. I have a side question.
How much different does the intake sound without the silencer?(with the silencer hole plugged hole of coarse)
Dan
Old Sep 24, 2003 | 10:51 AM
LT1TONY's Avatar
It doesn't sound any different.
Old Sep 24, 2003 | 11:54 AM
LT1TONY's Avatar
Here you go. Check the link out.
http://www.thunderracing.com/index.c...yid=1011#T1545
Old Sep 24, 2003 | 12:47 PM
turbo_Z's Avatar
you can do a search for Jason Cromer and order a 1LE intake elbow which has that air silencer deleted or you could just tape it shut with some duct tape i guess. either way you need to close off that leak.
Old Sep 24, 2003 | 01:05 PM
You might want to add a "signature", including the year of your car, and other relevant information. Not all years are the same. For example, the above info applies to 94 and later models, running mass-air. The "unmeasured" air entering the opening, after the MAF sensor will cause a major bog.
However, if you own a 93, running speed-density you should not experience a bog, since that leak will not affect the air flow calculations significantly. Of course you would still be pulling dirty, unfiltered air into the engine......
Old Sep 24, 2003 | 01:40 PM
jasons93z's Avatar
why pay $60 for an elbow when you can just plug the hole?
Old Sep 24, 2003 | 02:58 PM
Ever read a post about getting a shampoo bottle cap (or other item used as a plug) wedged in the throttle blades? I have.
blac94Z
Nov 4, 2015 01:59 PM
WobblySausage
Oct 7, 2015 02:44 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
