Signs and Sounds of a collapsed lifter
Old May 9, 2004 | 11:18 PM
JennyOnNos's Avatar
just what the title says. What are they? I am having a ticking sound that I believe to be a lifter.
and yes, easier stuff has been checked. Thanks
Old May 9, 2004 | 11:21 PM
Spinner's Avatar
tick tick tick tick tick tick tick tick tick
Old May 10, 2004 | 07:36 AM
JennyOnNos's Avatar
will i experience any power loss? or will the tick go away at higher rpms?
Old May 10, 2004 | 07:40 AM
PoorMan's Avatar
I have heard that many times it will make noise more when cold or hot (cann't remember) given the same rpm. Unlike a loose rocker arm that makes noise all the time and a cam bearing that makes more noise the more rpm (independent of how hot/cold the motor is). Something like that.
Old May 10, 2004 | 10:29 AM
aintno6's Avatar
Well not trying to scare ya. But the way I found out I had a collapsed lifter was it would act up kind of funky. Car would do this thing like it was missing. Well one day I fired her up, and I recieved the dreaded knocking noise from a bent valve
This is what I would do If I were you.
1. Find out what side of the motor it is comming from.
2. Tighten up the exhaust bolts on that side. (exhaust leaks can be very funky trust me)
3. pull off the valve cover , and look for loose valve train, if you find none. Then turn the car on, and see if you can pin point it with the valve cover off.(not hard unless its the passanger side, because the altanator need to be removed.)
Hope this helps.
Old May 10, 2004 | 01:46 PM
JennyOnNos's Avatar
Originally posted by aintno6
Well not trying to scare ya. But the way I found out I had a collapsed lifter was it would act up kind of funky. <A TITLE="Click for more information about car" STYLE="text-decoration: none; border-bottom: medium solid green;" HREF="http://search.targetwords.com/u.search?x=5977|1||||cars|AA1VDw">Car</A> would do this thing like it was missing. Well one day I fired her up, and I recieved the dreaded knocking noise from a bent valve
Hope this helps.
Thanks for the help. My car is kinda doing the missing thing. It's not bad, but it is almost like a lag and not a miss. I have done steps 1-3...that's why I think it is a lifter.
btw, what exactly happens when a hydraulic lifter collaspes? What could cause it?
Old May 10, 2004 | 06:05 PM
Spinner's Avatar
When it "collapses" the spring on the inside of it breaks/loses tension, etc. That leads to the roller not being pushed onto the cam all the way, and being pushed too far inside of the lifter itself. It can lead to cam damage, bent rods/valves, etc. If your worried, pull all your lifters and push down on the tips to check.
Old May 10, 2004 | 08:24 PM
JennyOnNos's Avatar
so in other words, take it easy till it is fixed
Old May 10, 2004 | 08:36 PM
Spinner's Avatar
Pretty much
Old May 10, 2004 | 09:08 PM
JennyOnNos's Avatar
Pretty much
thanks for the info and help spinner
what can cause a lifter to fail or go bad?
Old May 10, 2004 | 09:22 PM
Spinner's Avatar
Miles, stress, lost oil pressure, big lift or spring pressure on high miles, bad luck, particulate crap in the engine. Lifters start to go south around 100k miles and get worse from there on. It's not uncommon to have one go bad.
Old May 11, 2004 | 08:35 PM
"White Knight"'s Avatar
You have me scared now...........i have a tick tick tick noise during acceleration when it's cold. I don't hear it later.....also when i gas it it seems to respond slower than i would expect....but maybe it's in my head. Also it acts weid at high rpm like it's stuck and then jumps the last 500rpm and shifts. Should i check the lifters?
Plus the best i can muster at the track is 14.1 at 99.26.........i do have 2.73's and a gone posi, but maybe that could also be a prob.
Old May 11, 2004 | 09:14 PM
JennyOnNos's Avatar
When was the last time you did a tune up and tightened header bolts?
Old May 11, 2004 | 09:23 PM
Tony Danza's Avatar
Miles, stress, lost oil pressure, big lift or spring pressure on high miles, bad luck , particulate crap in the engine. Lifters start to go south around 100k miles and get worse from there on. It's not uncommon to have one go bad.
Bad luck is all it took for my tainted engine.....
Cherish your healthy engines!
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
mrwz28
Jul 8, 2015 09:11 PM
