Signs of a collapsed lifter or loose rocker?
Old Feb 10, 2005 | 12:58 PM
crAzy95z28's Avatar
ok well ive been hearing this ticking noise when i start up, and when i rev up to about 1500-2k rpms!!
it goes TICk, TICK, TICK....TICK.........TICK................TICK!!
well when i rev it up it gets a bit louder...and ive noticed the sound comes from under the car on the passenger side, but is louder underneath than on top...
form what i might know, i could have a loose rocker that jsut needs tighten...its not hitting the valve cover, but making a tick noise!!
what could this be and how bad could a collapsed lifter cause?
please help asap
thanks
Randy
Old Feb 10, 2005 | 01:39 PM
crAzy95z28's Avatar
Re: Signs of a collapsed lifter or loose rocker?
actually, i havent checked that out!!
ive had them in soo long in the passenger side and have neever taken them out since my cam change...been bout 8-9 months!!
ill check that out today, but it does make it sound like a exhaust leak on the passegner side, but a tick noise!!
ill let you later after i get off work!!
thanks
Randy
Old Feb 10, 2005 | 01:56 PM
Bersaglieri's Avatar
Could also be a broken spring. Pop off the valve covers and take a look, inspect everything very closely.
-Dustin-
Old Feb 10, 2005 | 02:14 PM
zx1216's Avatar
A lot of the time that noise is an exhaust leak, if a lifter is broke it will be more of a clanking sound probably, see if you can feal around the manifold or header fo an exhaust leak.
Old Feb 10, 2005 | 06:11 PM
crAzy95z28's Avatar
well checked out everything is good so far....,maybe im just gettng paranoid, cause my vavletrain was also kinda noisy and a lil bit ticky, but maybe its time for new headers...because my driver side got a hole in it, and now im thinkin the passenger will be there as well!!
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
