Side marker socket wiring?
Old Feb 26, 2003 | 03:29 PM
z28sinx's Avatar
This is what I need to get to: passenger side marker socket wire, the part where the wires lead to into the rear of the car. Where does that go and how do I get to that. Thanks.
Old Feb 28, 2003 | 06:38 AM
z28sinx's Avatar
ttt
Old Feb 28, 2003 | 02:29 PM
Not exactly sure what you want. To get to the bulb, you merely remove the T-15 torx screw on the outside, pull that end out a little, then pull the lens toward the rear to release the locating tab on the front of the lens.
The wiring comes in from under the speaker panel and behind the Bose speaker (if you have one). The harness goes through the body and outside to the LH tail lamps. The circuit for the marker branches off there and goes between the bumper cover and the body over to the marker.
Old Feb 28, 2003 | 03:03 PM
z28sinx's Avatar
Thumbs up
Okay cool, I just needed to know where the wiring comes in from, thank you.
Victor Lamb
Aug 26, 2017 02:52 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
siguy
Nov 27, 2014 10:07 AM
slocody
Feb 10, 2003 01:04 PM
RedLineRev
Jan 23, 2003 03:51 PM
