Should I be worried that heads may leak?
Old Dec 11, 2010 | 09:50 PM
djm_e22's Avatar
I was installing my heads with arp studs and I put W30 oil on the washer, nuts, and stud threads. As I was torquing the nuts down the oil must have made it down the short studs at the lower part of the head and some had seeped out between the gasket and head. Should this be a concern?
Old Dec 12, 2010 | 08:28 AM
Re: Crap, should I be worried that heads may leak?
I don't see any mention of thread sealant. That would be a major concern (especially since studs are notorious for leaking coolant without a very good seal).
Old Dec 12, 2010 | 11:39 AM
bw_hunter's Avatar
I'd be concerned if I was you...I would wonder if the head was fully seated when you set it on the block. It the heads was seated and properly torqued down then nothing should be able to seep out. If you're sure the head was seated....is it possibly warped?
Old Dec 12, 2010 | 02:54 PM
my1994z28's Avatar
Re: Should I be worried that heads may leak?
As Shoebox stated,what about thread sealant?Did you use any?
Old Dec 13, 2010 | 11:38 AM
Z28SORR's Avatar
It would bother me! I'd be worried that the head weren't seated right.
I like the liquid Teflon. Both the holes and stud threads must be clean and dry before coating the threads with the Teflon.
rideordie
Nov 5, 2019 04:52 PM
Roadie
Feb 16, 2015 10:34 AM
ModdedNerd
Jan 29, 2015 07:23 PM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
blac94Z
Nov 28, 2014 01:53 PM
