Should I use "Stop Leak"
Old Jan 4, 2004 | 12:44 PM
SNEAKY NEIL's Avatar
I seem to have a slow leak comming from where the water pump mates to the block. I was thinking about trying one of those "stop leak" products you pour in to plug leaks. Is this a good idea or should a stay away from that? Thank you.
Old Jan 4, 2004 | 12:47 PM
NOMAD's Avatar
Cool
Not only will it stop your leak, it will clog up your entire coolant system. If you ever see older cars with brown sludge floating in the sstem, it's probably coolant system sealer 90% of the time.
Just pull the pump and replace the gaskets, it will probably be cheaper actually.
-Shannon
Old Jan 4, 2004 | 02:42 PM
NewbieWar's Avatar
-Shannon
that is generally true ive heard many complains of ruining the water pump w/ usage of these leak fixers.
Old Jan 4, 2004 | 02:46 PM
I usually try to stay away from "fixit" additives. Correct the real problem. You will be much happier in the long run. Heck, you might just have a loose bolt.
Old Jan 4, 2004 | 02:57 PM
PredatorZ28's Avatar
yeah your gonna fix it for like two weeks and then it will be back
Old Jan 4, 2004 | 03:00 PM
Well yeah, i guess i will just go ahead and do it right. I just hope my opti does not become a casualty of the repair. Thanks guys.
Old Jan 4, 2004 | 04:14 PM
NOMAD's Avatar
Heck, thats easy. When you got to the parts store for the gaskets, just keep the plastic bag you get when you check out. Before you crack the bolts on the pump, get under the car and hang the bag over the top of the opti. Problem solved since you've bagged the opti I call it the AutoZone opti protection system
-Shannon
Old Jan 4, 2004 | 05:03 PM
95BlackTA's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
4586
Sep 27, 2015 01:55 PM
KYWes
Sep 26, 2015 08:49 AM
mark0006
Sep 14, 2015 12:35 PM
Aaront810
Sep 11, 2015 11:24 AM
