should I use locktight on header bolts??
Old Dec 18, 2003 | 12:23 PM
ba96ta's Avatar
what strength locktight should I use on header bolts
Old Dec 18, 2003 | 12:28 PM
ksmyss's Avatar
no dont use loc tight on the headers. the heads are aluminum and it will be next to imposable to get the bolts out.
just tighten them good and run the car through a few heat cycles and check/retighten them. after 1-2 checks they will be good to go
Old Dec 18, 2003 | 12:32 PM
suprchrged400's Avatar
you won't be a happy camper when the exhaust gaskets blow if you locktite them. If you have problems with them backing out. Check out thunder racing they have those special bolts with some device that slips over them to prevent that.
Old Dec 18, 2003 | 01:05 PM
anaik's Avatar
Use a dab of anti sieze.
Old Dec 18, 2003 | 01:32 PM
lt1hatesme's Avatar
just get locking header bolts
Old Dec 18, 2003 | 01:47 PM
BradZ28's Avatar
I've done LT1 headers 3 times never had the bolts back out and never retightened after the initial install. Just crank em down good the first time and be done with it.
Old Dec 18, 2003 | 03:10 PM
Don 97 SS's Avatar
I use 1" ARPs with a dab of antisieze and have never had any problem in 5 years with my Camaro's header bolts or gasket leaks.
Old Dec 18, 2003 | 03:24 PM
ba96ta's Avatar
Thats what I got the 1" arps I guess I'll just slap them in then.
Thanks for the replys
Joe
Old Dec 18, 2003 | 03:26 PM
ibanez6rg's Avatar
I used ARP bolts, no problems. Didn't even re-tighten them.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
