should I use locktight on header bolts??
no dont use loc tight on the headers. the heads are aluminum and it will be next to imposable to get the bolts out.
just tighten them good and run the car through a few heat cycles and check/retighten them. after 1-2 checks they will be good to go
you won't be a happy camper when the exhaust gaskets blow if you locktite them. If you have problems with them backing out. Check out thunder racing they have those special bolts with some device that slips over them to prevent that.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
