Should I go for it or not? (h/c)
Old Jul 27, 2007 | 08:01 AM
  #16
Javier97Z28's Avatar
Moderator
Originally Posted by truedualws6
There is really no degreeing an LT1 cam if you are using a stock or
extreme duty timing set. As said before, you are just verifying that
the cam is ground correctly. I attempted to check mine durng the
install, bought a degree wheel, already had a dial indicator on a
magnetic base, and never did feel like I could tell +-1*. It was sort
of frustrating to not be able to know exactly where it was. In the
end all I can say is it's within 2* of spec. It may have been more
productive if I had a helper.
Absolutely incorrect. You can use whatever timing set you'd like and stick an offset crank key in there to resolve the problem.
Mine was just about 3* off, stuck a Mr. Gasket 987G offset crank key in the crank slot and brought it within 1*, and it was pretty much where I wanted it to be when I took into account chain slack over time.
I was able to tell +/- 1*, even with a small comp degree wheel. Bigger wheels would do even better.
Old Jul 27, 2007 | 09:45 AM
  #17
Sweetred95ta's Avatar
Originally Posted by 95z28man
(especially knowing I saved $1800 or more)
$1800 A buddy's shop of mine around here does cam swaps for $425. Heads/cam for $650.
Old Jul 27, 2007 | 09:56 AM
  #18
dangalla's Avatar
Originally Posted by JP95ZM6
As for keeping track of all the parts, I got a few boxes of various ziplock bags and some seedling planter trays. You know, plastic trays with about 20 4' square bins in them. I labelled all the bags (silver sharpies write on about anything) with what the fasteners held on or where the parts came from, and numbered the bags in order of disassembly. Then I put them in the bins in order, to make the right bag easier to find later. I labelled the bins, too, in case they got tipped over or the bag labels got smeared.
this is very good advice and i recommend the same, i even do this at work sometimes
Old Jul 27, 2007 | 12:37 PM
  #19
95z28man's Avatar
Yea... when I heard that I was speechless. I was thinking more along $800-$1000 max. It's crazy. And that was if everything went smoothly... but it never does.
Bignasty85
Mar 3, 2015 04:05 PM
alphaauto
Jan 22, 2015 08:02 PM
Z28Venom
Jun 2, 2004 08:00 PM
AlexBarabas
Mar 16, 2003 02:19 PM
