Should I be concerned about LT1 intake on this setup being a restriction?
Re: Should I be concerned about LT1 intake on this setup being a restriction?
I dropped off the LT1 intake yesterday at Lloyd's to get a full port job, thanks all for the replies, I'll let ya know what it ends up making once its all back together.
It'll look something like this when he is done.
http://i63.photobucket.com/albums/h1...s/DSCF0215.jpg
That's a lot of porting
What kind of gains can be expected from having my intake ported by Lloyd on the motor in my sig? My motor is not 100% done yet, so if its worth it I'd like to do it before I start the engine for the first time... And how do I tell if I have the rectangle port of the tapered port LT1 intake?
All right, got my intake back from Lloyd, its all ready to go. here's a few pics of it
http://www.hometown.aol.com/onebadws...TA-intake1.jpg
http://www.hometown.aol.com/onebadws...TA-intake2.jpg
http://www.hometown.aol.com/onebadws...TA-intake3.jpg
The insides don't look quite as shinny as the pic link in the previous post because the carb cleaner dulled it when I cleaned out the inside...but the outside is nice and clean now and gave it a shot of hi temp aluminum paint.
Does Lloyd do any welding by the injector bungs before porting the intake? If not, thats a big step being missed out on.
Nick
Nick
Nick
Nick
Any other pics I can take to help verify I can snap and post up, but better tell me tonight as I'm dropping it off in the morning at my friends shop to complete the cam/head install.
The way it was explained to me was;
TB holes ported out to 58mm
Intake roof raised behind the inj
As much of the ski slope as possible removed (without falling through)
Ports matched to heads.
3lbs of material removed from the intake
I know some shops weld on additional material to allow more porting.
That was not (as far as I can tell) what he did in this case.
The LT4 intake I run on my setup was welded behind the injector, then ported. That "ski jump" that you see in your pic, is eliminated on my intake. I used to have a before and after pic of a welded/ported intake port versus just a ported in take port somewhere, and the difference is pretty big. I believe it was some time ago, but Jordan Musser posted a pic of this done on an intake. I dont have any pics of my intake done, but my builder did tell me that a butt load of metal came out of it when all was said and done. Even with the welding done, he still broke through, and there is a nice coat of epoxy above the weld.
Nick
Nick
Ok, I think I see where ya'll are talking about. If I understand correctly, then extra metal would have to be added on the top side of the bung closest to the plenum. I think that was what was done for my friends LT4 as well as making it fit an LT1 casting head. From my understanding, Lloyd does not do that normally and if its required I think Denny said someone else did his cutting/welding on the intake. I don't think my 350 will need any more than what its got done to it though. Maybe an aftermarket one..if anyone ever produces it will have some of those things already in the casting fixed.
Jul 4, 2005 05:00 PM
