should i change my opti while the engine is out?
the engine/opti has 107k on it. should I replace it? It works fine but I dont want to put it back together and then have it foul up on me. Let me know what you think...
well you all seem to agree. my budget actually doesn't have room for all this, but I guess I can elininate a few other things within the budget of my daily life to make room... like electricity, food, and a few others
thanks for the input!
Opti's are definately wear items. At 107k miles, its a good time to replace, especially if the engine is out. Do the plugs and wires too. The stock water pump isn't prone to failure like a belt driven design, but it makes sense to replace it too, since you have it off. Otherwise, the old one will probably fail and douse your new opti.
When younget a chance, disassemble the old opti, and you'll be glad you replaced it. The rotor and carbon button will be worn.
Sergio
Jan 27, 2016 04:27 PM
Alex Barnes
Jan 24, 2015 10:21 PM
