View Poll Results: Should I cam LT1 at 185k miles
Go for it and cam it
19
76.00%
don't push your luck
24.00%
Voters: 25. You may not vote on this poll
Should I cam engine at 185k?
Old Feb 11, 2009 | 11:40 PM
Big454blockchevy's Avatar
I know it's risky but I can't get rid of the itch to atleast cam the engine. I will eventually add some heads(either dart pro or loyd elliot's) after rebuilding the short block but for now I am thinking of camming my lt1.
Old Feb 11, 2009 | 11:43 PM
6SpdLT1Z's Avatar
might as well
Old Feb 12, 2009 | 12:10 AM
'94 Bad A Z28's Avatar
Do it!
Old Feb 12, 2009 | 12:31 AM
user 647483's Avatar
If it's running well and not consuming oil it should be just fine.
Do you know the complete history of the motor?
Old Feb 12, 2009 | 12:46 AM
I got the car at 112k on the odometer . Since then I have taken good care of it . Your usual maintenance . The only thing left to do before I move ahead with the cam is perform a compression check on all cylinders.
Old Feb 12, 2009 | 12:51 AM
http://www.dietersmotorsports.com/Co...akdowntest.htm
Old Feb 12, 2009 | 12:58 AM
Originally Posted by James Montigny
Thanks!
Old Feb 12, 2009 | 02:15 AM
bombebomb's Avatar
Might as well if it has made it this long. I personally would not, but chances are you have more cash then me right now haha. Just make sure the install is good.
Old Feb 12, 2009 | 06:22 AM
RamAir95TA's Avatar
I would! Like others have mentioned, as long as you perform a leak-down test and it isn't consuming oil, have at it!
Old Feb 12, 2009 | 03:55 PM
96' Formula WS6's Avatar
If its your dd Id say no if not Id say yes.
Old Feb 12, 2009 | 08:56 PM
mrmint69's Avatar
Just don't use a hammer to install it and you should be fine. That guy only got a few miles out of his.
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
