View Poll Results: Should I cam LT1 at 185k miles
Go for it and cam it
19
76.00%
don't push your luck
24.00%
Voters: 25. You may not vote on this poll
Should I cam engine at 185k?
I know it's risky but I can't get rid of the itch to atleast cam the engine. I will eventually add some heads(either dart pro or loyd elliot's) after rebuilding the short block but for now I am thinking of camming my lt1.
I got the car at 112k on the odometer . Since then I have taken good care of it . Your usual maintenance . The only thing left to do before I move ahead with the cam is perform a compression check on all cylinders.
oldschool
Feb 9, 2016 09:21 PM
