Should i buy SLPs Fan Control Switch?
Well i just bought one myself today. But there is a better way. That is to just make one yourself. Its not that hard to do really. You should be able to get all the parts to make one at radio shack. But when i went to all 3 radio shacks around here none of them had more than 1 or 2 parts that i need. So i decided on searching around anymore for the parts and just buy one.
I made my own but i keep blowing a fuse in my fuse box.My dad talked to ls1speed and they said if i were to buy gears to send them my module that they would set my fan temp,speedo,idles speed and everything else you can do with a hypertech for me from just buying gears.
I tried the fan switch mod and it kept setting an error code so I took the lazy man's way out. I bought another fan relay and socket and wired it in parallel with the existing relay and wired a switch to turn it on. Now the computer doesn't know what is happening downstream of the relay.
Where should i mount my switch. I think it would be cool to have a switch with the LED lights but i dont want to go chopping into my dash. Where are some good places to mount a switch?
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
