Should the fans be on all the time that the A/C is on?
Old Aug 26, 2005 | 04:37 AM
BlackLT1_TX's Avatar
I dont think my fans automatically come on with the A/C and I thought that they were supposed to. If they are, what could be causing them to not come on with the a/c, yet they still opperate normally otherwise and all the relays are good.
-James
Old Aug 26, 2005 | 06:21 AM
Tom Piper's Avatar
Re: Should the fans be on all the time that the A/C is on?
I think the F-body is the same as the Y-body.
On the Y-body, the cooling fans are controlled by:
1) Coolant temperature
3) Oil temperature
3) A/C high-side pressure ( this equates to condensor temperature)
4) Limp-home mode of the ECM -- the fans run all the time, regardless
The ECM can turn off the fans regardless of sensor readings after the vehicle reaches a certain speed -- I think this is about 40 mph.
When the A/C high-side sensor senses a pressure above a certain point, the ECM turns the fans on -- this happens most of the time the A/C is on.
The cooler the ambient temperature is the less the fans will be activated by the A/C.
Tom Piper
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
ChrisFrez
Feb 1, 2015 08:26 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jul 4, 2005 05:00 PM
