!rear 02s no simulators
Old Aug 25, 2005 | 08:34 PM
CamaroSS30thAnn's Avatar
is there any dissadvantage of not running with sims in the rear 02s
right now i have no cats b/c of teh long tubes, i do not have any simulators
i have had a problem where i am either not getting enough spark or im getting too much fuel causing a missfire and plugs being fouled,
could no sims in teh rear cause my computer to act funny and do this?
thanks
bobby
Old Aug 25, 2005 | 08:58 PM
Re: !rear 02s no simulators
No, but the fact that the SES light is on continuously may be masking other problems that might set an SES.
Old Aug 25, 2005 | 11:46 PM
i realize that , i had the codes checked and i get random misfire code p0300 or whatever teh code, is it seems to only happen on teh left bank but i will get more info as soon as possible im just wondering if in someway i damaged teh opti
are the headers causing my car to run rich? do u really need a tune after headers?
Old Aug 26, 2005 | 12:48 AM
lt11997's Avatar
The first thing I would do is check your plug wires.
P0300 is a random misfire code, If you have access to a Tech 2 you can go and lookup previous misfires and it will tell you how many misfires each cylinder has( one of the cylinders would have hundreds and the rest would probably read 0).
Unfortunately it doesn't say which cylinder it is in the code like ford. For ex. on a ford PO301 would be cylinder 1 misfire.
Old Aug 26, 2005 | 07:28 AM
97FormulaWS-6's Avatar
Bobby,
My first guesses would be leaky Header Gaskets and/or a burned plug wire(s). That would be my starting point.
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
maybe2fast
Mar 16, 2015 11:59 AM
Injuneer
Dec 15, 2014 09:36 AM
