Shorty Headers and Y-pipe
Old Jun 8, 2009 | 01:37 PM
jfbamf's Avatar
I currenlty have a set of SLP shorty headers that mount to the stock flanges and keep the CAT'S in place. Im looking for a aftermarket Y-pipe that i can use that will mount up to the headers i already have and do away with the CAT'S. Does anyone know where i could find this?
Old Jun 8, 2009 | 11:36 PM
You would probably be better off starting with a new set of headers. The SLP CARB-EO dual-cat header primaries are all twisted and convoluted to keep the drivers side cat in the correct location. Without the cat, you can use better headers.
Otherwise, you will have to find a "no cats high flow" stock Y-pipe replacement.
Old Jun 9, 2009 | 12:53 PM
reamo04's Avatar
jegs has a "Jegs ORY" that works with stock manifolds.
Old Jun 9, 2009 | 12:56 PM
jfbamf's Avatar
You wouldnt happen to know the part# would you?
Old Jun 9, 2009 | 12:57 PM
jfbamf's Avatar
Injuneer any recomendations? I dont have an unlimited source of money so i need an economical set.
Old Jun 9, 2009 | 02:52 PM
mzgp5x's Avatar
I have SLP short style headers on 97ss. Jet coated. I have a Random dual cat Y pipe with twin cats. I did a little cutting on the driver side cross pipe & Mig welded, but it was an easy fit. The problem is with the gasket seal on the left side. I modified a 2 1/2" copper flange (from Summit) with 1/8" rivets. It now seals good with a even torque sequence. I used a 3" on the Rt side header gasket flange. I also did a Mufflex 3 1/2" cat-back w/ qtp cut out. It flows good now with a 383ci - D1, and, I have good engine access and ground clearance. I moved the left side O2 sensor down stream for better access. I don't think SLP makes the shorts anymore. HTH. B.
Old Jun 9, 2009 | 05:03 PM
reamo04's Avatar
here ya go
http://www.jegs.com/p/JEGS/JEGS-Off-...64015/10002/-1
RallyRed701/2
Jul 27, 2015 02:55 PM
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
