What next?
Old Dec 25, 2006 | 02:38 PM
Mortify's Avatar
What next?
Alright so Mods are in sig... I'm thinking of going true duals (Will I see a good gain?), cam it (cc503) or 3.90s?
Old Dec 25, 2006 | 02:40 PM
2000GTP's Avatar
You'll see the best gain with the cam, then I would do gears, and if money permits, true duals last.
Old Dec 25, 2006 | 03:23 PM
RE AND CHERYL's Avatar
I think I'd do the cam first too. That muflex 4" system will flow about the same as a dual 2.5" system.
Old Dec 25, 2006 | 03:24 PM
reamo04's Avatar
keep the mufflex system, do cam, then gears
i wouldnt even screw w/ duals unless u dont like the soundof ur current setup
Old Dec 25, 2006 | 04:34 PM
CamaroRacing12's Avatar
do the cam, then the gears..... cam will give u the most gains... but remember all the necessary parts and the cost of it all.... installation ecpecially if u cant install it urself
Old Dec 25, 2006 | 06:04 PM
Mortify's Avatar
Are there any kits for the 503, I already have 1.6 RR and factory hardened pushrods... I know I should replace the lifters, locks and springs (beehive).
How much would I be looking at for everything I have listed EXCEPT the cam itself?
Old Dec 25, 2006 | 06:06 PM
1995greenTA's Avatar
Why not maybe an electric water pump, pro 5.0, mail order tune, or some suspensin? SFC LCA TA?
I would highly suggest getting a pro 5.0 and either chopping the stick 1.5" or getting a short stick. Huge improvement
Old Dec 25, 2006 | 06:10 PM
reamo04's Avatar
idk, ive drove a m6 camaro w/ a pro 5.0 and didn't like it, so maybe he's in the same boat, or drives fine w/ the current shifter.
id go w/ maybe LCA, SFC, TA, cam, tune, drag radials and gears, tune again,
if you can, save up and do gears and cam at the same time so u only have to tune once
Old Dec 26, 2006 | 01:24 PM
Mortify's Avatar
Would it be better to focus down onto suspension with Stiffer springs, Performance shocks, LCA's, and maybe bigger swaybars?
This is a summer DD but I love to have fun in her. I think she handles great already but compared to my previous car I think shocks and springs would help considerably..
Old Dec 26, 2006 | 01:57 PM
95LT1conv's Avatar
http://www.compperformancegroupstore...Code=K08-503-8
check this kit
Old Dec 26, 2006 | 03:29 PM
CustomSSI's Avatar
Camshaft or suspension are both great ideas.. And we can give you a bit of a "package" price on everything if you want.. Shoot us a PM if your interested..
