Shoebox or just any body please help!!!!
Old Jun 27, 2003 | 03:49 PM
dnz28's Avatar
I got out of my car and went into the house came out and my car wouldn't crank. I Have checked all the connections and battery level and they all seem good I think it may be my starter but I have never seen one Act fine then just not work at all another minute. Any ideas. Please help I am On the edge and Am think of selling this heep and getting a bike.
Old Jun 27, 2003 | 04:04 PM
Need more info. Is everything else normal, but just won't crank? When you say "won't crank", do you mean the starter does not crank or the engine does not fire up? (some people use the terms interchangeably).
Old Jun 27, 2003 | 05:13 PM
dnz28's Avatar
starter will not crank. All the lghts in the dash dem like it is about to start but no starter crank.
Old Jun 27, 2003 | 05:17 PM
I would check your battery connections and connections at the starter. The purple wire at the starter should have 12v on it when the key is in the START position. Sounds like it might be the starter.
Old Jun 27, 2003 | 05:48 PM
dnz28's Avatar
I also have another question I never noticed but the securtiy light is flashing and was wondering if that could cause my car not to start.
Old Jun 27, 2003 | 05:55 PM
TobyZ28's Avatar
Your engine starter may be disabled because of the security system. I'm not sure exactly how long it stays that way, i think its 10-30 minutes or something... It can happen if your key is really dirty...
Someone might have more info on disabling the engine lock sooner, a towtruck guy i know said you can lock and lunlock the car around 4x with the key manually and it should disable it. .but i'm not sure
good luck, check the voltage on the terminals. If your car starts acting really weird like only the secuirty light is on, and if you remove and reconnect the battery the siren goes on really quietly and louder and quieter.. i'll be pretty sure its the batter thats dead... Mine did exactly that on sunday night and i found out the batter was leaking and was nearly dead.
Old Jun 27, 2003 | 06:13 PM
That's a BIG thing to leave out. That is why I asked if everything else was normal. Forget everything I said before.
Old Jun 27, 2003 | 07:13 PM
Mtrhds94Z's Avatar
Try cleaning the pellet on the key.. or jiggle it around a bit..
mark0006
Apr 21, 2015 12:42 PM
CARiD
Feb 9, 2015 09:35 AM
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
