Shoebox, here is one for ya! What timming set works with 97 lt1??
Old Jun 24, 2003 | 12:09 PM
SSCamaro's Avatar
Been outta the loop and have forgot. I also did a search and found noda. If I remember correctly, Cam gear changes along with optis(?) but what about chain and lower gears between the 93/4 and 97?? WHat is, if any, interchangeable between motors??
Old Jun 24, 2003 | 02:27 PM
As stock, 93-94 cam sprockets are interchangeable (spline drive opti). 95-97 cam sprockets are interchangeable (dowel pin drive opti).
The chain and crank sprockets are interchangeable for all 93-97.
The crank hub is interchangeable 93-95 and then a shorter one for 96-97 (because of the crank position sensor).
Old Jun 24, 2003 | 04:09 PM
SSCamaro's Avatar
Thank you, thank you for the quick responce.
Red Hawk 94
Mar 18, 2019 04:03 PM
parkers Z28
Mar 11, 2016 08:14 PM
Rod Bender
Jan 3, 2015 03:15 PM
thenewkid
Nov 29, 2014 04:54 PM
siguy
Nov 27, 2014 10:07 AM
