shoebox gotta header ?
Old May 1, 2004 | 12:11 PM
TrouserSnake's Avatar
Ive heard you have to lift the motor on the passenger side.. to get a hooker Lt in.
Which should I unbolt to make it the easiest to bolt back in off the motor or the frame? also what do people jack on? the Oil plan with a block of wood Id guess
Old May 1, 2004 | 12:17 PM
I have not done it, but I would assume that removing the one through bolt in the mount would be what to do. Jacking on the pan is at your own risk, though I have done it myself. Just make sure you use some wood to distribute the load and go slow, so you can watch for any binding or problems.
Old May 1, 2004 | 02:31 PM
DonHood's Avatar
I wouldn't put the jack on the oil pan at all. The place I've used before was the transmission housing, closest to the front.
Old May 1, 2004 | 02:54 PM
ChevyIron's Avatar
When I installed the hooker long tubes I had to remove the motor mount threw bolts on both sides.I jacked it up on the crank hub with a block of wood.
97SS0594's Avatar
i guess he got it done now!!! congrats trousersnake!!
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
DarkKnight
Exhaust System
34
Sep 6, 2015 06:20 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
