Cat. problem on 96Z
Old May 1, 2004 | 01:24 PM
brians96Z's Avatar
Cat. problem on 96Z
The cars runs fine, so I don't think they are clogged up. I bought some o2 simulators to go behind the converters from Summit, and they're working so far. Has anyone used them?
Old May 1, 2004 | 02:10 PM
mc28's Avatar
i've got a 96 Z and i just had to use some simulators to pass smog on friday. you'll need to clear any codes you've got in the computer (assuming thats why you bought the sims) and then hook up the simms. They immediately solved the problems i was having so i was happy with them.
Old May 1, 2004 | 02:21 PM
HBHRacing's Avatar
Then why did you put 02 sims in? they will not fix a problem with the cats. They are just there to help not set a check engine light when you gut, remove, or buy high flow cats. if there is still a problem with teh cat or front 02 it will continue to be an issue
Old May 1, 2004 | 03:08 PM
brians96Z's Avatar
I installed the sims because the only problem with the cats is that they are letting too many fumes through, and thus kicking on the SES light. For OE replacement cats, my local GM garage wanted 400 and something a piece. This was my least expensive option. Guess I could take them clear off, make them strightpipe. I have had problem with exhaust rattling in the past, after being messed with. (I know it don't happen everytime)
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Compstall
Sep 9, 2002 02:16 PM
