shim flywheel?
Old Feb 21, 2003 | 08:34 AM
blkchevyz's Avatar
shim flywheel?
do you need to shim the fly wheel? i've had it turned a few times now. if so how much? is their a way to mic the flywheel to see how much was removed?
thanks
Old Feb 21, 2003 | 09:38 AM
95 Z/28 LT1's Avatar
Super Moderator
I don't think you need to shim anything. When they machine the flywheel they only take off like a thousandth or two. The hydraulics should more than make up that kind of distance. Have you noticed the clutch engaging higher each time you have had the flywheel turned?
It might tend to warp easier if enough material has been removed though.
I too would be interested if anyone has a method to mic the flywheel, and had some specs that it is supposed to be within.
Old Feb 21, 2003 | 09:42 AM
blkchevyz's Avatar
the friction point never moved the first two times.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
