shim flywheel?
I don't think you need to shim anything. When they machine the flywheel they only take off like a thousandth or two. The hydraulics should more than make up that kind of distance. Have you noticed the clutch engaging higher each time you have had the flywheel turned?
It might tend to warp easier if enough material has been removed though.
I too would be interested if anyone has a method to mic the flywheel, and had some specs that it is supposed to be within.
Formula Steve
Sep 19, 2023 08:31 AM
karpetcm
Sep 29, 2015 10:08 AM
