Shift Light install on a 93
Old May 17, 2004 | 08:31 AM
Gripenfelter's Avatar
Anyone have a guide on the net?
Basically need to know which wires to tap into and where.
Old May 17, 2004 | 11:17 AM
ttt
Old May 17, 2004 | 11:35 AM
importeater's Avatar
On OBD2, its C1 (Red) Pin 13, a White wire "Engine Speed Output Signal" I would imagine its the same for OBD1.
Craig
Old May 17, 2004 | 11:44 AM
C1 being the connector on thye back of the PCM?
Can you use the negative coil wire or is that a bad idea?
Old May 17, 2004 | 11:56 AM
Yep C1 is the red connector of the four going into the computer. Dont know about the negitive wire on the coil, Shoebox could probably tell you. I would imagine it does though because thats all the MSD boxes use. Try it and let us know
Craig
badblackta's Avatar
the solid white wire that comes off of the coil is the one you need. There is also a solid white that comes off of the computer, you can use that one too.
Old May 17, 2004 | 12:18 PM
I'll try the coil. Hopefully it doesn't cause any misfires.
Old May 17, 2004 | 12:41 PM
Pasky's Avatar
Which plug on the coil for the solid white? I believe there are two solid white's on the coil, may be wrong without looking.
Old May 17, 2004 | 01:29 PM
Are you talking about those two plugs that clip together and then clip onto the coil?
Are they 2 wires each?
Old May 18, 2004 | 09:23 PM
I have a fat white wire in pin 12. All the connectors on the back are red.
Any ideas?
Old May 19, 2004 | 11:28 AM
badblackta's Avatar
there should be only one solid white wire on the dual connector harness that connects to the coil. You can splice into that one. I used a wire nut, but you can also use a scotch lock,(I didnt have the right size).
Old May 19, 2004 | 11:59 AM
On the 4 wire connector right?
Old May 19, 2004 | 12:46 PM
badblackta's Avatar
yep. that is it
Old May 19, 2004 | 11:29 PM
Bud M's Avatar
I used the pink/black wire on the coil
Jason Short
Jan 19, 2015 06:34 PM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
