shift light install ?
Old Jun 17, 2009 | 08:57 AM
Z28avalanche's Avatar
I know I get the signal from white/black wire out of PCM, but where is everyone getting the power from and where are you grounding to?
Old Jun 17, 2009 | 05:23 PM
You can get power from the fuse panel at the end of the dash. There is a spade lug, marked "IGN" (switched power). That's good for the +12V to the tach. For a ground, any screw under the dash that screws into a metal chassis part will work.
Old Jun 18, 2009 | 07:48 AM
I'm going to run the power wire to the "ignition on" at the radio and the ground also.
Jason Short
Jan 19, 2015 06:34 PM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
