shift light install on 1994 z
Old Oct 22, 2003 | 02:02 PM
Prorac1's Avatar
I am installing a autometer shift light on my 94 z and am trying to figure out which wire off the coil is the tach lead. any help would be appreciated. thank you. Prorac1
Old Oct 22, 2003 | 02:53 PM
atljar's Avatar
There should be a white wire going from your coil to the ECM. That is the tach wire. Pin # 13, in the red connector is where it plugs into the computer. Prolly easier to grab it there, than at the coil
Old Oct 22, 2003 | 02:56 PM
x7x7's Avatar
or white/black@coil
Old Oct 22, 2003 | 05:52 PM
Prorac1's Avatar
cool, thank you for the info guys. prorac1
Old Oct 22, 2003 | 08:28 PM
Bud M's Avatar
I used pink/black at the coil.
Old Oct 22, 2003 | 09:02 PM
12SCNDZ's Avatar
I spliced into the wire going to my cluster/stock tach
Frank
Old Oct 22, 2003 | 10:41 PM
Prorac1's Avatar
i ended up using the white with the black tracer by the coil and it worked great. put in a 3000 test module and winged it up to 3000 and the light flashed on. and i figured out that my tach is 100 rpm fast. thank you for all the help guys. thanks again prorac1
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
