she just turned off on me
OK i was on my way to race and my car just shut off. i warning nothing just shut off. i checked for spark nothing but the interesting thing is i have no fuel now. is there anything else i should check for? i am going to work on the car tomorrow night and check the power to the pcm anything else i should look for?
Have you scanned it for codes?
What year is the car? Might want to add a "signature", with basic info - year, model, engine, tranny and any major mods. That will help people help you.
sorry well its interesting. my lt1 is from a 95 caprice and its in an 88 rx7. i have no idea what else to lok for i was told right away its my opti and i didn't know what else to look for. fuel pump is running with a 9v battery but its not running in the car what other signs can i look for i am going to scan the car on friday see if i have any codes
If for example, the Opti is not putting out the low resolution cam position signal (DTC 16), the PCM will shut down the fuel system - pump and injectors. It should still prime for a couple seconds when you turn the key to on, then stop. Does the pump start at all? Have you tested the fuel pump using the "fuel pump prime connector"? That bypasses the fuel pump relay and the PCM.
There should be a gray connector in the wiring harness near the PCM (not sure if thge B-Body harness matches the F-Body harness though). You apply 12V to the prime connector. Shoebox has a photo of the F-Body setup:
http://shbox.com/1/fuel_pump_prime.jpg
jasonduaine
Jun 4, 2015 09:29 AM
formula79
26
Aug 5, 2002 12:21 PM
