poly mounts didnt help
Old Jul 8, 2009 | 01:19 AM
wheelliftnpony's Avatar
longtubes are chattering off what sounds like floor panels. i read that poly mounts have helped that for some people. whats next if they dont fix this? they make just as much noise.. thay are prothane mounts from summit. thanks
Old Jul 8, 2009 | 01:33 AM
ACE1252's Avatar
They must be making contact somewhere. You need to find it and eliminate the contact.....or get some better fitting headers.
Old Jul 8, 2009 | 09:02 AM
wrd1972's Avatar
Lower your transmission crossmember using 1/4" square washers. This will lower the collectors away from the floor. Takes 10 minutes and fixed.
Old Jul 8, 2009 | 12:37 PM
good idea.. i will try that. thanks
Old Jul 8, 2009 | 03:48 PM
wrd1972's Avatar
Dont overdo it or you might get driveline vibes. Start with 1/4". Should not take more than 1/2" or so.
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
War Engine
Sep 18, 2015 07:28 PM
Daluchman1974
Sep 11, 2015 06:12 AM
