shaky idle....
Old Dec 31, 2003 | 10:43 AM
Hyperspeed97z28's Avatar
shaky idle....
at idle I can feel it shaking a little bit... I've replaced new o2 sensors monday night, smoother but still a stumble or something at idle. have wires with about 15k or less on them and I dont feel they or the 15k plugs are the problem. runs like a beast all out the rpms but at idle shes shaky.... MAP sensor? TPS ? what sensors are left ?
Thank you,
Keith
Old Dec 31, 2003 | 11:05 AM
gamecockfan04's Avatar
Mine too! I dont know what else to do. Ive replaced plugs, wires, O2's, coil, cleaned TB, changed fule filter, fuel pump, cleaned IAC and TPS, no cat, so what the hell else could it be. Like you said mine runs fine through out the RPM range its just a stumble every other second at idle.
Old Dec 31, 2003 | 11:09 AM
95TA8280's Avatar
I replaced the PCV valve in my 95TA and it smoothes out my idle a bit......
Old Dec 31, 2003 | 11:12 AM
anyone got a part # for the groment around the pcv valve? I think I'm gonna try that and a new groment.... I've got newer/new plugs/wires/ coil/ icm/o2's just about everything....
Old Dec 31, 2003 | 11:34 AM
Let me know if it helps.
Old Dec 31, 2003 | 12:27 PM
Cmr0z28's Avatar
Hey -- pry the PCV valve out with a screwdriver and shake it. If you hear it rattling, then it's fine. If not, it's clogged and should be replaced.
Old Dec 31, 2003 | 03:32 PM
I know about the PCV, it hasnt been replaced in about 40k so it might be time to just do it anyways.. I'm thinking a new gromet for sure though. no need to pry it out, just pulls right out...
Anyone have the part # for a new rubber gromet? Might as well replace them both at once....
Do you think it could be the map/tps sensors?
Old Dec 31, 2003 | 03:48 PM
NewbieWar's Avatar
wires dont matter their life span, i replaced mine a while back and 40 miles later the bumpy idle returned...
i guess the pullys sucked it up
Old Dec 31, 2003 | 04:10 PM
wish there was a way to tell excactly what wire or wires were the culprit...
Old Dec 31, 2003 | 05:15 PM
neil350's Avatar
I have had my car for close to 4 years now and it has always had a very slight shake at idle time to time. Its just like that real slight surge problems have, bunch of cars haveit but no one knows why. If all our cars have it, I dont think its any thing serious.
Old Dec 31, 2003 | 05:58 PM
ChickenScreamer94's Avatar
I can accept the shake at idle, i mean heck, its not a bmw or anything, it is a $20K 350 CI American V8. My car has always had a little shake in the idle, and that has been since 27K miles, and 30K miles later it does it still, maybe a little worse, but that comes with age. I need a tuneup, which is coming soon, and will most certainly smooth it out.
Now the surging is a whole nother monster. Ihave had that for about 4k miles or about a year. That **** P*sses me off. I have greatly reduced it by relocating my IAT. Dont know why, but it did ? It is only a bandaid though. It isnot a thing that since nnumerous cars do it that it should be thought of as normal.
Old Dec 31, 2003 | 06:07 PM
weird, sometimes its worse then others... sometimes it isnt that bad....
Old Dec 31, 2003 | 06:59 PM
HesterZ28's Avatar
iac
Old Dec 31, 2003 | 07:17 PM
EbeZ28's Avatar
Borg Warner: PCV271
Old Dec 31, 2003 | 07:42 PM
Cmr0z28's Avatar
I too have a shaky idle but something is up with my EGR (got an SES)....blocking it off soon.
