Shaking franctically when driving 80mph!
Old Jun 1, 2008 | 12:17 AM
lt1stroker's Avatar
My whole dash board and car shakes pretty crazy when im hitting like 80mph+. Could it be my sub frame connectors? Help. Specs:96 z28, 216k on odo, 16k on rebuild
Old Jun 1, 2008 | 01:08 AM
TeamingTealZ28's Avatar
Bent rim?
Old Jun 1, 2008 | 01:43 AM
lt1stroker's Avatar
^ Like my rims with tires or my rim from my bodY?
Old Jun 1, 2008 | 01:45 AM
What?
Old Jun 1, 2008 | 03:22 AM
tlillard23's Avatar
Originally Posted by TeamingTealZ28
What?
+1
and no, it's not your subframe connectors
Old Jun 1, 2008 | 08:55 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
The stock driveshaft has been known to cause vibration at higher speeds.
Old Jun 1, 2008 | 09:33 AM
30696bird's Avatar
The drive shaft probably needs to be turned 180*. It's balanced and it matters which way you put it on.
Old Jun 1, 2008 | 10:46 AM
Ratlor's Avatar
I would also question the balance of your front and rear tires/wheels. If a couple ounces of weights accidentally fell off one of your wheels, it could cause it to shake pretty well.
Old Jun 1, 2008 | 12:07 PM
JasonK94Z's Avatar
If you have a steel driveshaft, its the suspect. GM had a lot of problems with unbalance steel shafts leaving the factory. If thats the case, pick up a used ls1 aluminum one.
Old Jun 1, 2008 | 12:47 PM
lt1stroker's Avatar
^ Where can i pick a used ls1 driveshaft and how much?
Old Jun 1, 2008 | 02:55 PM
caldercay's Avatar
At a junk yard or ebay or the For Sale section.
Old Jun 1, 2008 | 05:53 PM
JasonK94Z's Avatar
Check the for sale section here and at other message boards.
Old Jun 1, 2008 | 06:20 PM
TasTe GOOD's Avatar
I bet it is the driveshaft because my girlfriends camaro does the same thing at 80+mph. I thought it may of been the tires not being balanced or something, but she just got new tires installed and balanced. I just put a ls1 driveshaft in my camaro, some people put those in to get rid of the vibration, but i did it because it was a 70 dollar aluminum driveshaft on ebay + 30 for u-joints and a easy 5 hp, but dont use aluminum driveshafts if you plan on going with high hp numbers.
mattstrike
Mar 12, 2015 10:12 PM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
wytblur
Aug 5, 2002 02:03 PM
dmaastr
9
Jul 1, 2002 02:22 PM
