set off codes
Old Feb 12, 2003 | 06:44 PM
lt4 fd's Avatar
set off codes
code 32.... something about the egr
code 84.... something about ... something
code 96.... something about an oil lamp
What are they and whats wrong?
Old Feb 12, 2003 | 06:50 PM
RamAir95TA's Avatar
Code 32: Exhaust Gas Recirculation Failure. Check vacuum source and all hoses. Electrical connectors/EGR valve, etc. You might need a new EGR solenoid.
Code 84: Skip shift control solenoid. Have you installed CAGS by some other method that would cause the SES light to come on? If not, then there's a fault in the skip shift circuit, or the solenoid itself in the tranny case.
Code 96: Transmission circuit low (3.4 liter engine only). You have an LT1 correct? Are you reading the correct code?
Old Feb 12, 2003 | 07:28 PM
Check your fan fuse. It powers some of that stuff.
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jan 23, 2015 01:13 PM
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
guionM
9
Aug 2, 2002 11:59 PM
