set off codes
Code 32: Exhaust Gas Recirculation Failure. Check vacuum source and all hoses. Electrical connectors/EGR valve, etc. You might need a new EGR solenoid.
Code 84: Skip shift control solenoid. Have you installed CAGS by some other method that would cause the SES light to come on? If not, then there's a fault in the skip shift circuit, or the solenoid itself in the tranny case.
Code 96: Transmission circuit low (3.4 liter engine only). You have an LT1 correct? Are you reading the correct code?
Jan 23, 2015 01:13 PM
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
guionM
9
Aug 2, 2002 11:59 PM
