ses problem
Old Jul 28, 2003 | 11:39 AM
klpps's Avatar
ses problem
I got a 97 z28 and just insalled an OR-Y. Things were great for 2 days until I got an SES code. The guys at the shop said it was an EGR problem but I forgot to write down the exact code. I got the code cleared but it came on 2 days later again. I've checked the o2 simulators on my friends camaro and they are working properly. I've also read somewhere about EGR and backpressure. I am running pacesetter shory headers, OR-Y, and a straight pipe as a muffler. Any suggestions on what might be the problem will be appreciated. Thanks.
Old Jul 28, 2003 | 11:51 AM
Crazy8's Avatar
Do you still have your cats? If you dont that would be the problem.
Old Jul 28, 2003 | 12:07 PM
Very common on the OBD-II cars (96/97) to get an SES light for inadequate EGR flow, when you reduce the backpressure in the exhaust system. Installing an offroad Y-pipe, on top of your headers was probably enough to cause the problem.
The only way you can be sure is get it scanned, get the exact code, and look it up in the tables at Rob/Shoebox's website, or the AutoTap website. The code tables that many shops use, or that show up on some scanners are very "generic", and often not model specific. There are several codes for EGR issues, including problems with either the EGR valve, the EGR solenoid, or others.
Old Jul 28, 2003 | 02:04 PM
klpps's Avatar
No, no cats. I still have my old setup so worst comes to worst Ill just throw that back on. I don't mind driving around with my ses on its just I'm worried that something else may blow up and I won't know about it. I will get the exact code asap and post it here and look it up. Freckin' obdII.
Old Jul 30, 2003 | 12:39 AM
klpps's Avatar
ok gf out of town and I've been on baby duty. Havent gotten a chance to hit up autozone yet. I was wondering if putting egr block off plates will make my egr ses go away?
Old Jul 30, 2003 | 02:02 PM
No, the plates won't cure the SES light. The PCM looks for flow by watching the MAP sensor. If it doesn't see flow... whether its because the valve is stuck, exhaust system backpressure is too low, or you installed blockoff plates, it turns on the light.
Old Jul 30, 2003 | 05:26 PM
klpps's Avatar
I'm pretty sure my egr problem had to due w/ out enough back pressure. I bolted back on my flowmaster muffler in place of my straight pipe and the ses light went away that night. gg. =)
Old Aug 19, 2003 | 12:03 PM
doodad's Avatar
Did you have any performance issues when the engine was cold?
Old Aug 19, 2003 | 12:38 PM
klpps's Avatar
no problems, just that ses light.
Old Aug 19, 2003 | 01:03 PM
TenaciousZ's Avatar
I'm having similar problems when the engine is cold! I recently had an ORP and hooker LT's installed. I unhooked my 02's and the "stumbling when the engine is cold" went away
Old Aug 19, 2003 | 06:15 PM
doodad's Avatar
Have you now replaced them and that solved the problem? I thought about doing that Thursday when I am on the dyno.
Old Aug 19, 2003 | 10:36 PM
john96ws6's Avatar
Geeez, I just got hooker LTs and an off road y-pipe and am having the same problem. No power loss or anything just the SES. Will it hurt anything? I am getting it scanned this weekend.
Not to jack your thread or anything!!
Old Aug 20, 2003 | 04:32 AM
doodad's Avatar
Fair warning I didn't at first either. Then the EGR code popped and it is getting old fast. Also, if you have some kind of tuning like HPP, take it off it hurts ya.
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Gtpguy
Jan 26, 2015 04:50 PM
Rich_z28
Sep 13, 2002 03:35 PM
Timberwolf
Aug 18, 2002 07:39 PM
